Activity › Forums › Apple Final Cut Pro Legacy › RE: SDTI (QSDI) issue
  • RE: SDTI (QSDI) issue
    Posted by Michael on February 14, 2006 at 7:05 am
    Hi guys, I’m having a problem and I am trying to figure out if it’s the deck or my ignorance. Perhaps someone can point me in a direction. I’m working with a DSR-80 using the SDTI (QSDI) out spigots of the deck. This will go into an AJA Io eventually, but I’m seeing a gray screen with a purple band on the left side of the screen about where you’d see the white bar in a test pattern. Is there something about SDTI I don’t know, or is the SDI board in the deck fried? I’ve checked it in two places with the same result.
    Michael
    Gabe Lucero replied 16 years, 8 months ago 2 Members · 2 Replies
  • Michael
    February 14, 2006 at 7:54 am
    Never mind.. just found an online primer.. Thanks.
  • Gabe Lucero
    January 28, 2010 at 3:51 pm
    Hey, this is the best that I have found for my same problem here trying to go from the qsdi on a dsr-80 to final cut pro 6 by a kona 3 card and bob.
    You mentioned you found something online. Would you mind sharing that?
    thanks
