Activity Forums Apple Final Cut Pro Legacy Re-rendering of footage?
  • Re-rendering of footage?
    Posted by Paul O’ neill on September 17, 2009 at 12:21 pm
    Hey Guys,
    First post here, have looked through the forums and can’t find a similar post, but apologies in advance if this question is already out there (i’m sure it is)
    I’m a newbie to FCP and i’m working on some footage for a music video…most of my clips are effects based (membrane, lensflare etc) having messed around and rendered them i’m happy with what i have…My question is if i have rendered a clip (some of them, small 5-10 sec clips take about 11 minutes) and want to copy them repeatedly on the time line do i have to keep re-rendering them?
    The way i’m using FCP now it appears that i have to, just wondering if there is a way around this..
    Thanks in advance,
    Paul.
    John Fishback
    replied 16 years, 11 months ago
    2 Members · 1 Reply
  • John Fishback
    September 17, 2009 at 3:06 pm
    Copying and pasting a rendered clip should work without a re-render if it’s a standalone clip. If you place it over another clip, then you’ll have to render. You can try exporting the rendered clip as a QT with current settings, and then Import it to use. However, if you’re placing that clip over another clip, you’ll probably have to re-render.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
