Activity Forums Maxon Cinema 4D Re-render a scene – only pieces though – any way to mask?
  • Re-render a scene – only pieces though – any way to mask?
    Posted by Brian Murphy on December 15, 2019 at 4:20 pm
    Hey guys,
    I have a scene through which I’ve animated a camera. The scene has been fully rendered but I see some small unwanted spheres accidentally placed above the ground of the scene that show as the camera runs by them. I need to render a pass with only a small perimeter around each sphere after deleting the unwanted spheres and composite that into the scene – so basically I’ll have a render of the scene with the spheres and a separate “clean-up” render of just the areas where the spheres were without the spheres. I need to render little “windows” of the corrected parts of the scene, perhaps surrounded by black or a color of my choice. Any one know a way to do this so I don’t have re-render the scene again?
    I’ve done this countless times with a scene that has one unwanted object by using a plane, coloring it like a greenscreen and cutting out some polygons to mask the area to be corrected but these spheres are scattered throughout the z axis so there’s depth to this cleanup job.
    Brian
    Steve Bentley replied 6 years, 9 months ago 2 Members · 1 Reply
  • Steve Bentley
    December 17, 2019 at 8:45 pm
    Not quite sure what you are after there but have you tried making the spheres (or slightly larger versions of the spheres) matte objects with a compositing tag?
