Activity Forums Apple Final Cut Pro Legacy RE: No Communication in FCP log and capture
  • RE: No Communication in FCP log and capture
    Posted by Jlfcp2007 on March 16, 2007 at 10:50 am
    I am trying to log and capture footage from a small HD Sony HDV Handycam. I am using a fire-wire cable. Every time I load log and capture, the log and capture screen has the message ‘No Communication’ at the bottom and has the preview disabled. I haven’t a clue what is wrong with it, do I need to do something with the settings? Please help….
    J.L
    Fernandez_is_go replied 19 years, 5 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    March 16, 2007 at 2:31 pm
    Try using the Easy setup for HDV using the format that was shot… i.e. 1080i60?
    Should be using sony’s HDV device control setting for sure.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Fernandez_is_go
    March 17, 2007 at 11:58 am
    Hi Jerry,
    I am having some serious problems with capturing using the Sony V1. Been trying different machines with FCP 5.0.4 & 5.1.4, different device control and different cables. The message underneath the capture preview window drops out saying “searching for media” every 10-20 seconds and if I capture now and stop capture, none of the clip has been captured. I have seen some talk of the V1 having such problems but can find no solid advice or knowledge.
    If you have any ideas or leads on who to ask I’ll be greatly appreciative. This is really making some headaches on my timelines!
    Thanks, Nick
