Activity Forums Media 100 RE: Media 100i LE 8.2.3 not working outside Media 100 app
  • RE: Media 100i LE 8.2.3 not working outside Media 100 app
    Posted by Gerrym on February 25, 2006 at 9:59 pm
    Im running Quicksilver 933 G4 – system 10.3.9
    Quicktime – 7.0.4
    I uninstalled 8.2.1 and installed 8.2.3…
    Media 100 application works fine…
    but Quicktime Player, Cleaner, bring up a white video screen??
    I uninstalled and it was fine??
    any suggestions?
    gerry
    Gerrym replied 20 years, 6 months ago 3 Members · 5 Replies
  • Gerrym
    February 25, 2006 at 10:00 pm
    Sorry, Its the old Vincent 601 board…
    Have I come to the end??
  • Kieran Matthew
    February 25, 2006 at 10:18 pm
    I had a similar problem a while back and it was cured by downloading and installing the software codecs from Media100.com.
    I don’t know if it will cure your issue, but it is worth a try!
  • Gerrym
    February 26, 2006 at 2:23 am
    Well, I tried the software codec… but no success…
    Its either the end of the line for the Vincent board… Though shes had a great run!
    or maybe Tiger is the solution?
    Anybody running a G4 with tiger, and the old Media 100 vincent 601 & software 8.2.3?
    gerry
  • Floh Peters
    February 26, 2006 at 11:08 am
    If QuickTime based applications don
  • Gerrym
    February 26, 2006 at 9:49 pm
    Thanks for your response,
    Turns out I had to take the Media hardware codec out of the LIBRARY/QUICKTIME for both the main system and the user library…
    So it looks like me old Vincent board is still going to chug along with the SD format for a while longer…
    I guess i will be missing the classic Media 100 warning
    ” Your hardeware is in use by another app… quit Media 100 blah…blah…blah…”
    Viva la Media 100!!!
    thanks again for your suggestions…
    gerry :{)
