Activity Forums Adobe After Effects Re Map Quality low
  • Re Map Quality low
    Posted by Fred Gates on February 24, 2012 at 10:42 am
    Hi I’m evaluating Re:Map
    and the quality is terrible is this a limitation of the Demo or is there something I should now.
    cheers
    Jim
    senior animator
    MGV London
    Fred Gates replied 14 years, 7 months ago 2 Members · 2 Replies
  • Peter Litwinowicz
    February 24, 2012 at 6:43 pm
    Not sure what you mean by “quality is low.” Do you mean it’s rather pixelated or coarse?
    Two things to check:
    1) make sure your UV map(s) are exported as 16 bit or floating point from your 3D system.
    2) make sure your project (for example, within AE) is set to 16 bit or floating point.
    If you continue to have problems, send us a sample project (AE, Nuke, etc.) and some UV maps and source texture map(s) so we can take a look. You can send that to us at techsupport (at) revisionfx (dot) com.
    Pete
  • Fred Gates
    February 27, 2012 at 10:50 am
    cheers,
    my render wasn’t 16 bit.
    all sorted thanks.
    senior animator
    MGV London
