Activity Forums Zaxwerks Re: making a lego block in 3d invigorator Pro
  • Re: making a lego block in 3d invigorator Pro
    Posted by Mark Joseph on June 27, 2007 at 6:50 pm
    ok, so i got it together my only question now would be,
    is it possible to group together two different objects
    inside invigorator?
    Jon Okerstrom replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    June 27, 2007 at 11:35 pm
    Hi Mark,
    You can group any number of objects together in what are called sets. Think of sets as invisible containers.
    When you animate, you control the movement of the sets rather than individual objects.
    The only caveat – the number of available sets is limited, so if you want to individually animate lots of lego blocks you might have to use multiple instances of the Invigorator effect.
    Does this help?
    Jon
