Activity Forums Apple Final Cut Pro Legacy Re-linking original audio in sequence
  • Re-linking original audio in sequence
    Posted by John Forsen on November 21, 2010 at 1:05 am
    I edited a sequence with “b” roll video only over some talking heads. Now I want to put in that ambience audio in tracks 3 and 4. When I double click the video going back into the viewer, it only has the video no audio. There must be a shortcut to go back to the original source and get that audio, without finding the clip finding the TC and reinserting that audio
    JF
    John Forsen replied 15 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 21, 2010 at 1:14 am
    Park the Playhead on the clip. Press X to mark IN and OUT on that clip. Press F to MATCH FRAME to the original clip. Map the audio to 3 and 4, disconnect the V1 tab (so you don’t add the video again). Press F10 to OVERWRITE new audio.
    Repeat. X…F…F10.
    Shane
  • John Forsen
    November 21, 2010 at 1:57 am
    Shane
    thanks so much, how simple and yet critical
    JF
