Activity Forums Apple Final Cut Pro Legacy re-linking deleted sound to FCP clips
  • Jeremy Garchow
    January 7, 2007 at 4:42 am
    Where do you delete the sound? Timeline? Capture Scratch Folder?
    If you deleted from the timeline simply do a matchframe back to the original clip and then edit the sound only into your timeline.
    If you deleted off of your hard drive, then you must recapture.
    Jeremy
  • Herotree
    January 8, 2007 at 6:51 pm
    Thanks Jeremy. i should have said the problem is that I have a whole 90 minute timeline with a thousand clips and I’m trying to figure out how to do this en masse – as oppposed to mtchframing every clip… any ideas?? Thanks again
  • Jeremy Garchow
    January 8, 2007 at 8:14 pm
    So if you match frame one of the clips, does it have sound, or did you capture audio and video separately and delete just the sound?
    Sorry man, looks like you have some work to do.
    Jeremy
