Activity › Forums › Apple Final Cut Pro Legacy › RE; jittery frames on DVD playback
  • RE; jittery frames on DVD playback
    Posted by Nelson May on June 8, 2006 at 4:48 am
    I have been getting advice from the Studio section and I still am not able to solve my problem. After I author a DVD, I get frame lag and ghost images while being played on a commercial DVD player. I tried mixing down my track into a .mov file. Then I imported it in into Studio. Just as a control group, I took the .mov file and played it back on a 30 in cinema display. i am seeing some slight ghosting. I have tried chaging field order in studio and anything else I can think of. It was also suggested that any audio files should be converted to .ac3.
    Anyway, the point is, I may be having problems with my export to a .mov file. Has anyone had this problem? Should I export at different settings? Should I try to render my timeline again and see if there is anything that shows up?
    Nelson May replied 20 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 8, 2006 at 3:27 pm
    What codec are you working with? DV? or?
    Jerry
  • Nelson May
    June 8, 2006 at 3:29 pm
    Using DV.
