Activity Forums Adobe After Effects re-interlacing issue
  • re-interlacing issue
    Posted by Xav Vonl on August 16, 2011 at 10:16 am
    Hi folks !
    I’m getting sort of a brain-lock here….
    I have a couple of 1080p movies that need being converted to 1080i.
    I followed the steps detailed here
    https://magazine.creativecow.net/article/interlacing-progressive-footage
    so I have my 25fps footage with doubled frames, conform it to 50fps, import it to a 50fps comp and make a 25fps upper frame first render….
    but then I have a weird result, my output footage is progressive all the way to the middle of the file and then I get the interlace effect I’m after….
    This is driving me f*****g MAD :/
    Xav Vonl replied 15 years ago 2 Members · 2 Replies
  • Walter Soyka
    August 16, 2011 at 1:19 pm
    [xavier loebl] “so I have my 25fps footage with doubled frames”
    You don’t want doubled frames — you want motion estimation to calculate new frames in between the existing ones.
    Use Time Remapping (making sure that Layer > Frame Blending > Pixel Motion on), Timewarp, or Twixtor to create a slo-mo version of your clip that runs at 50% of the speed of the original.
    Walter Soyka
  • Xav Vonl
    August 17, 2011 at 10:27 am
    Thanks for your advises, I knew I was missing something here.
