Activity Forums Adobe After Effects Re Flex or morph node in skake
  • Re Flex or morph node in skake
    Posted by Gwuill on August 10, 2007 at 3:25 pm
    What is better between Re: vision Reflex in after effects and the morph node in shake? I need to do a morph between two person (not just the face) in front of a blue screen. I’ve seen a tutorial in shake using the morph node and it seems to be a lot of work with the shapes (rotoscoping). Is it like that with Reflex?
    Thanks for your quick answers!!
    Nicholas Toth replied 19 years ago 2 Members · 1 Reply
  • Nicholas Toth
    August 10, 2007 at 3:41 pm
    Demo Re-flex from reelsmart. It’ll watermark your result, but you’ll see direct results.
    Then try shake. Compare them side by side.
    It shouldn’t take that long for both of them.
