Activity › Forums › Adobe After Effects › Re-drawn section in psd not updating properly in After Effects
Posted by Jon Simpson on September 25, 2013 at 3:16 pmHi, Im having a strange issue in AE. I drew a larger bicep in place of the original in a psd that I am animating with the puppet tool in AE. For some reason, the newly drawn parts are only partially showing and the mesh is missing from the newly drawn areas. Also, I cant figure out why the bottom line of the tricep is showing and the rest isnt. Attached is a shot of the area, complete with the mesh and a shot of what it is SUPPOSED to look like from the psd. Thanks in advance!
Jon Simpson replied 13 years ago 5 Members · 16 Replies -
Joseph W. bourke
September 25, 2013 at 7:31 pmTry going to the PSD in your Project tab of AE, selecting the PSD file, right-clicking, and choosing Reload. That should do it. If not, try closing, then reopening the project.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Todd Kopriva
September 25, 2013 at 10:34 pmWhat version of After Effects?
After Effects team blog
Todd Kopriva
September 25, 2013 at 10:56 pmWhat happens if you purge the RAM and disk cache ( Edit > Purge > All Memory & Disk Cache )?
Jon Simpson
September 26, 2013 at 12:05 pmBtw, thank you very much for your help.
Clearing the cache and memory did not work and neither did a reload. I am wondering if this has something to do with the puppet pins that were already placed when I re-drew the arm?
Jason Jantzen
September 26, 2013 at 3:49 pmIs it a layered comp by any chance? If it is, and you added a new layer to your PSD with the new artwork, it won’t show up. Only existing layers in the layered comp will update.
Jason Jantzen
vimeo.com/jasonj -
Jon Simpson
September 26, 2013 at 6:19 pmIt is a layered comp, yes. However, I did not create a new layer, I drew on an existing one and part of the drawing is showing up in AE, but it does not animate with the rest of the layer it is on.
But this explains why the layer I created today is not showing up, thanks! I will just import that on its own, but the drawing I did on an actual layer should update properly. I’m confused.
Jon Simpson
September 26, 2013 at 6:54 pmOkay, now it is getting bizarre. I went ahead and imported the updated PSD and when I copy/pasted the puppet effects onto the new version, the same part of the arm that I drew on the other one disappeared as well. So this is definitely a puppet pin thing.
Jason Jantzen
September 26, 2013 at 8:52 pmWelcome to the world of Puppet Pinning 🙂 Get used to meshes doing weird things unexpectedly, especially if you’ve got everything set up like you want it and hit the 3D switch, or collapse transformations switch. You’ll figure it out I’m sure.
Jason Jantzen
vimeo.com/jasonj
