Activity Forums Maxon Cinema 4D Re-creating the Beauty pass from multipasses in After Effects using Arnold for Cinema 4d
  • Re-creating the Beauty pass from multipasses in After Effects using Arnold for Cinema 4d
    Posted by Ryan Ainge on January 16, 2017 at 5:00 pm
    When I work using standard render I always re-create the beauty pass using my multi-pass so I can tweak reflections,shadows, etc. With Arnold there are so many different passes, and I’ve tried re-creating it to no avail. I’ve read online this:
    direct_diffuse + indirect_diffuse + direct_specular + indirect_specular + refraction + deep_scatter + mid_scatter + shallow_scatter + primary_specular + secondary_specular = Beauty
    This is mostly for nuke as you can create the RGB from a non-separated multipass. How do I do this for AE? Any people out there that have done it?
    Adam Trachtenberg replied 9 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 16, 2017 at 9:26 pm
    I don’t have Arnold but I would imagine you would stack the passes using Add mode.
