Activity Forums Panasonic Cameras re-create P2 card
  • re-create P2 card
    Posted by Marcus Vasques osorio on February 1, 2009 at 4:03 pm
    I want to playback from a screen from my panasonic P2 cards, the material I want to play back is old material so basically want to recreate the card with old material is this possible.
    In other words make a new P2 card from old P2 material (the file structure still remains)
    Marcus
    Marcus Vasques osorio replied 17 years, 6 months ago 4 Members · 6 Replies
  • John Fishback
    February 2, 2009 at 4:17 pm
    Raylight for Mac can make a P2 card from Quicktimes. https://dvfilmstore.com/raylight-for-mac.html
    I’ve read of other apps that can also do this, but don’t recall the names. Try searching mxf on the Cow to find them.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Marcus Vasques osorio
    February 2, 2009 at 6:02 pm
    Ok fine, but I have already got the original P2 material so I do not need to convert it. All I want to do is place it back on the card (selected clips) and be able to play them back through the camera onto a monitor…
    Marcus
  • John Fishback
    February 2, 2009 at 6:15 pm
    I’m assuming you have a means of getting the P2 files from the P2 card to your drive. We use a Duel Adaptor with a MBP. I’ve never tried this, but I suppose you can copy the files from your drive to a freshly formatted P2 card. Just make sure all the files are put on the card in the same order they were originally. Let us know if that works.
    John
  • Jeremy Garchow
    February 3, 2009 at 12:34 am
    [Marcus Vasques Osorio] “Ok fine, but I have already got the original P2 material so I do not need to convert it. All I want to do is place it back on the card (selected clips) and be able to play them back through the camera onto a monitor… “
    Yes you do. The P2 MXF structure is one that is all tied together. In order for it to work properly new metadata files must be written to reflect what your media is using (timecode, audio and video tracks, all kinds of other goodies,etc). You need a program to do this, or if you don’t care about those things, then you can somply record your timeline out to P2 through a camera or other device. Those resulting MXF files will not match back to your orig. MXF files in any way.
    Jeremy
  • Tracy Peterson
    February 10, 2009 at 6:51 am
    He’s saying he’s got the original file structure, not a captured file structure. That means you just copy to a formatted P2, I think.
    Tracy Peterson
    http://www.onetwomany.com
    February 10, 2009 at 9:55 am
    thought I would update everyone, copying idividual files does not work. Whole cards neither there is some kind of playback aterfact very strange. So we did playback from a mac using FCP
    Marcus
