Activity Forums Adobe After Effects re-coloring only part of an animation
  • re-coloring only part of an animation
    Posted by Sscielzo on December 20, 2005 at 9:40 pm
    Hi. I’m not even sure AE can help, so please forgive me if the question is not relevant to this forum. Basicaly, I have an avi movie of a plane that is landing and I want to change the coloring of the plane’s flaps in red. The problem if I use a mask is that the flap region changes as frames go by. How should I go about tackling this problem? Thanks!
    Sscielzo replied 20 years, 8 months ago 3 Members · 5 Replies
  • Enzo Tedeschi
    December 20, 2005 at 11:14 pm
    If the plane’s flaps are a different colour to the rest of the plane already, then this tutorial on the COW might help:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/kahlenberg_roland/coolsville/index.html
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Sscielzo
    December 20, 2005 at 11:53 pm
    Thanks. Unfortunately the flaps are the same color as the rest of the plane. I did manage to get to change the shape of masks as time goes by in the movie. Now I just need to change the color inside the mask. Any hints?
  • Enzo Tedeschi
    December 21, 2005 at 6:46 am
    If you already have animated masks, then one way to do it would be to use a colour effect of some sort to affect the areas inside the masks.
    If you only have a single layer, then dupe it, and delete the masks from the lower layer. If your masks are set up right, you should have a layer with just your flaps showing, above the full image. If you affect the masked layer, you should have it…?
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Jim Kanter
    December 21, 2005 at 5:00 pm
    Put a new color layer on top of the airplane. Cut the animated masks from the airplane layer and paste them into the color layer above.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Sscielzo
    December 21, 2005 at 5:11 pm
    Thanks Enzo. Your suggestions helped me solve the problem. My red flaps look awesome now!
    Sandro
