Activity › Forums › Apple Final Cut Pro Legacy › Re. Color Grading: Color, Looks, Color Finesse?
Posted by Elin Grome on September 9, 2008 at 8:56 amRe. Color Grading
Hi guys,
Silly question from a (relative) noob… but can anyone explain to me what is the difference between the above apps… or more precisely why I should be using Apple Color instead of say Color Finesse (which is integrated with AE).
I am lucky enough to have all 3 apps at my disposal, and something tells me I should be concentrating my energies on Apple Color, given its heritage..
Elin.
Rafael Amador replied 17 years, 12 months ago 7 Members · 16 Replies -
Walter Biscardi
September 9, 2008 at 10:17 amColor Finesse is not realtime and it’s much more limited than Color, especially as Color has a Primary In, 8 Secondaries (16 if you could in the inside / outside of vignettes), the Color FX room and Primary Out giving you up to 19 individual layers of adjustments to each individual shot.
Looks is basically just a slap on filter. If you don’t want to think about what you’re doing and just want to apply a “look” to your project, this is a very simply plug-in.
Color is very in-depth and not for every user or every project. You simply cannot get the level of color grading adjustments in any other Mac based app than Color. You need to take the time to learn it much more than Finesse or Looks, that’s for sure, but once you get the hang of it, it’s quite simple.
You can get a lot more info on Color in the Color forum.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Rafael Amador
September 9, 2008 at 11:16 am[Elin grome] “why I should be using Apple Color instead of say Color Finesse (which is integrated with AE)”
Because you can send your FC time line as it is to Color.
If you want to send it to AE, you need AutmatickDuck.
I agree with Walter, the options you get in Color you don’t get in the other applications.
The secondary room is amazing.
Looks is great when you start to make your own looks, but is no really a CC application.
You need to make at least a primary CC with other filter before to apply it.
I think that a good ption could be ColorFiness in FC.
This would allow a very good CC without living FC and going RGB.
But probably if you start with Color you will stick with it.
Cheers,
Rafael -
Elin Grome
September 9, 2008 at 2:06 pmWell Im not afraid of a few hours of frustrated screaming at monitors and ploughing through forums, so color it is then…
Thanks guys – Im sure ill be back with some questions before long 🙂
Mark Raudonis
September 9, 2008 at 2:27 pm“A few hours…”
For many, this is a career! I think you underestimate the steepness of the learning curve ahead of you.
Mark
Walter Biscardi
September 9, 2008 at 3:15 pm[Elin grome] “Well Im not afraid of a few hours of frustrated screaming at monitors and ploughing through forums, so color it is then…
“More like a few days.
Read my Blog!
David Roth weiss
September 9, 2008 at 4:21 pm[walter biscardi] “More like a few days.”
Unfortunately, the steepest part of the learning curve is not color correction itself, but rather learning to deal with the Color’s various idiosyncrasies.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Ron Craig
September 9, 2008 at 5:40 pmAre there any good classes making the rounds to teach Color? Or, second-best: well-done tutorials?
Walter Biscardi
September 9, 2008 at 5:54 pm[Ron Craig] “Are there any good classes making the rounds to teach Color? Or, second-best: well-done tutorials?”
My DVD is pretty much everything I learned in a $1,500 training session. Definitely gets you started in the app.
Read my Blog!
David Roth weiss
September 9, 2008 at 5:59 pmGet Walter’s DVD and watch it first. I was using Color sucessfully fifteen minutes afterward.
Later, when you want to get into the real nuances of Color, check out the Ripple Training DVD. It goes very deep into Color and deep into the colorization process.
David Roth Weiss
Director/Editor
Ron Craig
September 9, 2008 at 6:00 pmI could have looked at your signature line! Duh!
I’m going to order it, Walter. Looking forward to it.
