Activity Forums Apple Final Cut Pro Legacy Re Capture? Disk Space? ISSSUES
  • Re Capture? Disk Space? ISSSUES
    Posted by Jessie on September 4, 2006 at 2:10 am
    i am cutting a 5 minute piece for esther on my macbook pro laptop. i am trying to re capture the footage that i had dumped previously for a specific cut to make some changes to it. for some reason im having trouble capturing JUST the media for that specific sequence. i have 20 GB of space to work with which should be plenty however, because it will only let me capture ALL the media, i wont have enough space. any idea why or how to get around this? i have tried breaking the link between the clips and their master clips, created another project and copied the sequence into it…etc. any help you can give would much appreciated.
    Andreas Karoliussen replied 20 years ago 2 Members · 1 Reply
  • Andreas Karoliussen
    September 4, 2006 at 6:59 am
    Hi Jessie,
    Try the Media Manager.
    select your sequence/clip > File > Media Manager > Create Offline > un check “include masterclips outside selection” > check “delete unused media from duplicated items”> check “Use Handels” if you like> un check: “include affiliate clips outside selection” > Base media file names on :”existing file names”
    Check ” Duplicate selected items and place into a new project”
    Select a media destination and a project name in the next window and on you go;-)
    hope this helps you out
    Best regard
    Andreas
