Activity Forums Apple Final Cut Pro Legacy Re-capture audio only 1394
  • Re-capture audio only 1394
    Posted by Jonathan Ramsey on May 19, 2006 at 8:14 pm
    Is it possible to recapture a clip’s audio only, via firewire? I have DVCam footage captured via component with the video levels all set and I want to use it as such, but want to recapture just the audio for each clip (I now have a chance to do some mixing on input and need to fix some gain levels) and it would be easiest for me to do that via firewire (don’t have a component out deck handy right this second)… didn’t know if I could use the firewire for audio and control only. If it is possible, will doing this have any negative consequences for keeping things synched?
    Thanks for your insights!
    Ramsey
    Jonathan Ramsey replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
