Activity › Forums › Apple Final Cut Pro › Re-atach Audio
  • Re-atach Audio
    Posted by Nathan Kendall on August 17, 2017 at 9:10 pm
    I am working on a project in final cut X were I detached a synced audio clip and forgot to reattach it after adding fx.
    Is there a way ro re align to the video clips like there is in FC legacy?
    I remember in FC7 if audio came out of sync it would let you manually sync with time code. this would be very helpful since I have cut my video in timeline.
    Jeremy Garchow replied 9 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 17, 2017 at 9:56 pm
    The only way is to copy the effects, match frame and replace the clip with audio, then paste effects back on to the clip. You should be able to add whatever effects you need without detaching.
