Activity Forums Avid Media Composer Re-adjusting Color Correction on clip – media composer
  • Re-adjusting Color Correction on clip – media composer
    Posted by Nancy L. sutton smith on October 26, 2014 at 2:01 pm
    I haven’t figured out how to select the color correction on a clip to re-adjust. Sometimes I will open color correction and I see the previous adjustments, other times I think I have it selected and CC applies a filler. How do I select existing color correction FX on a clip and change it?
    Nancy L. Sutton Smith
    Northeast Community College
    Mass Media/Journalism/Post Production Instructor
    Sutton Bay Media Company
    Shane Ross replied 11 years, 11 months ago 3 Members · 2 Replies
  • Michael Phillips
    October 26, 2014 at 3:11 pm
    Make sure you are only monitoring the track on which the clip lives. If you monitor anything above that, the color correction will get applied to that clip or filler if that is what is active at that point in the timeline.
    Michael
  • Shane Ross
    October 27, 2014 at 4:13 pm
    Go into the WINDOW menu, and choose WORKSPACES>COLOR CORRECTION. If a color correction effect was added to a clip, this is the only way to make adjustments to it. Need to be in a Color Correction window layout.
    Shane
    Little Frog Post
