Activity › Forums › Apple Final Cut Pro Legacy › Raw Files to Pro-RES Edit Conversion
  • Raw Files to Pro-RES Edit Conversion
    Posted by Mark Trifunovic on December 5, 2011 at 10:22 pm
    I am new to shooting on the Canon SLR series. I started editing a film in FCP straight from the Canon RAW files, because I did not realise that it is better to convert into Apple Pro-Res. My edit has become really slow and cumbersome as a result.
    I have since converted all my footage into Apple Pro-Res LT and have it stored on a separate hard drive to that of the original footage (I replicated the original file structure of the first hard drive, in case that helps…)
    Since I have already edited the film, I am trying to avoid having to recut the entire film with the converted footage.
    I am wondering if there is a way I can use the existing edit – in and out points, fades, transitions, etc. – but apply it to the new converted footage, without having to go through each individual clip again.
    Thanks in advance for your help. I am also a relative newcomer to FCP – I’d really appreciate it if you could explain as simply as possible how best to proceed.
    Thanks again,
    Mark
    Steve Eisen replied 14 years, 10 months ago 2 Members · 2 Replies
  • Mark Trifunovic
    December 6, 2011 at 6:55 am
    This is a Final Cut Pro query.
  • Steve Eisen
    December 6, 2011 at 1:41 pm
    [Mark Trifunovic] “I am wondering if there is a way I can use the existing edit – in and out points, fades, transitions, etc. – but apply it to the new converted footage, without having to go through each individual clip again.”
    Learn from your mistakes. You will have to re-edit.
    Here is a tapeless workflow for FCP:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
