Activity › Forums › Adobe After Effects › raster data expressions
Posted by Ben Insler on September 9, 2008 at 3:36 pmHey Cow!
Is there a way to access raster data of a camera through expressions. I’m looking to… say… take the top have the camera look at the upper left corner of the comp, average its pixels into one luma value, and tell me what that value is. Is that possible?
Ben
Dan Ebberts replied 17 years, 11 months ago 2 Members · 3 Replies -
Dan Ebberts
September 9, 2008 at 4:16 pmTo sample the pixel data of a camera view (is that what you’re asking?) you’d have to turn the comp into a precomp and drop it as a layer into another comp, where you could use sampleImage()on it to get at the pixel data. You’ll get back the averaged RGBA values for a rectangular area that you specify. Then you should be able to use rgbToHsl() to do the conversion (I think).
Dan
Ben Insler
September 10, 2008 at 3:36 pmGotcha. Thanks.
Turns out I’m using AFX 6.5 (i know…I know…), and that function wasn’t introduced until CS3. So I’ve come up with a new idea for driving the effect I’m looking for, but I’m having trouble with the driving expression. Can you have one expression, in one layer, drive many other layers. For example, if I have 10 solids (solid01 – solid10) in compA, and another solid (driver01) in CompB, can an expression use driver01.rotation to control the rotation of all 10 solids, without writing an expression for each?
I was hoping to do something along the lines of this in the rotation attribute of the driver solid (and I don’t know if the syntax is write here, just using it as an example):
for(i = 1, i<=10, i++) comp("compA").layer(i).rotation = rotation; The results of this don't calculate onto solid01 - solid10. However, if I write an expression for each solid's rotation in compA referencing the driver's rotation, everything works. Any way to just have one expression drive all? Thanks again! Ben
Dan Ebberts
September 10, 2008 at 3:42 pmNope, sorry. An expression can’t control anything except the property to which it’s applied.
Dan
