Activity › Forums › Blackmagic Design › Range Check brightness to monitor…is it fixed in new driver?
  • Range Check brightness to monitor…is it fixed in new driver?
    Posted by Mike J. on January 21, 2006 at 6:40 pm
    When you use Blackmagic Decklink (5.2 and FCP 5.0.3) and turn on range check…the monitor output brightens quite a bit. You can’t color correct this way then.
    Has this been repaired in the newest blackmagic driver?
    Mike J. replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
