Activity Forums Adobe After Effects Expressions Randomly move position of layer on Y within a range, hold for a few frames and move again
  • Randomly move position of layer on Y within a range, hold for a few frames and move again
    Posted by Nawaz Alamgir on May 17, 2019 at 1:58 pm
    I found this code
    Random position in a random amount of time and pause in this position for a random amount of time
    moveMin = .3; //minimum move time
    moveMax = .7; //maximum move time
    pauseMin = .1; // minimum pause time
    pauseMax = .5; // maximum pause time
    minVal = [0.1*thisComp.width, 0.1*thisComp.height];
    maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
    seedRandom(index,true); // set pre-run for endT
    endT = - random(moveMax);
    j = 0;
    k = 0;
    while ( time >= endT){
    j += 1;
    seedRandom(j,true);
    startT = endT;
    if (j%2){
    endT += random(moveMin,moveMax);
    k++;
    }else{
    endT += random(pauseMin,pauseMax);
    if (j%2){
    seedRandom(k,true);
    endVal = random(minVal,maxVal);
    seedRandom(k-1,true);
    startVal = random(minVal,maxVal);
    ease(time,startT,endT,startVal,endVal)
    }else{
    seedRandom(k,true);
    But just want this for the Y position of a layer only
    Dan, can you help if you have a sec? Many Thanks
    Nawaz Alamgir replied 7 years, 3 months ago 1 Member · 1 Reply
  • Nawaz Alamgir
    May 17, 2019 at 2:05 pm
    I figured out a method that words , and made this change to the expression
    minVal = [0,0.1*thisComp.height];
    maxVal = [0,0.9*thisComp.height];
