Activity Forums Maxon Cinema 4D Randomizing the step effector.
  • Randomizing the step effector.
    Posted by Curtis Doss on February 2, 2007 at 5:08 pm
    Heres the deal I have a poly sphere with with a saved selection. The selection is used with a mograph cloner object to grow a push pin out of each selected verticie. The growth of the push pin is controlled by the keyframes of the push pin itself. Is there a way I can randomize the growth of each clone so that the growth does not all happen uniformly at the same time (esentailly randomize the starting point of the animation? I am fairly new to mograph and very new to using effectors. Any help would be greatly appreciated.
    Adam Trachtenberg replied 19 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 3, 2007 at 4:56 pm
    You can use a Random effector on your cloner. Turn off the standard move/rotate/scale parameters and in “Other” parameters enter your frame count in the “Time Offset” box.
