Activity › Forums › Adobe After Effects Expressions › Randomize the Index…
  • Randomize the Index…
    Posted by Barry Brimley on September 10, 2009 at 3:52 am
    Hello. I was wondering if there is an expression that would allow me to randomize the index sequence. I’m assuming the manual way would be to rearrange the index, but with 200+ layers, that would take awhile, let alone making it look organic.
    The code comes from a tutorial over at https://www.graymachine.com. The final line is the one I believe would be the one to modify. The whole premise is that a layer will end at a certain position, and the animation of the layers are driven by the index. However, the object (in this case text), is made up of 200+ layers, and they were imported from Illustrator in a structured manor. I want the end result to have a random feel, instead of a very linear left-to-right animation.
    Thank you in advanced.
    seedRandom(index,true)
    start = random([-100, 50, -2000] , [1000, 436, 1000]);
    end = value;
    ease(time, 0, 2 + (index*thisComp.frameDuration), start, end)
    Barry Brimley replied 17 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 10, 2009 at 12:57 pm
    Try changing the last line to this:
    ease(time, 0, 2 + (random(thisComp.numLayers)*thisComp.frameDuration), start, end)
    Does that do what you want?
    Dan
  • Barry Brimley
    September 10, 2009 at 11:28 pm
    Wow, thank you so much man. You just saved me a headache, or ten. Haha. 🙂
    It did exactly what I wanted. Thank you!
