Randomize and repeat footage
Is there a way to play a sequence of small clips in a way that randomizes and replays clips? I am looking to create a stop motion effect with text animating on top of notebook paper. The focus here is on animating the paper. The paper will be wrinkled in different ways, which ultimately will be the clips. Each clip will play for two or three frames at a time. I figure I can record about ten clips with different levels of wrinkle. I would like to play the clips so that each clip is randomized and replayed so that I can create sequences for any length of time I need.
Does anyone have an idea how I might achieve this effect?
