Activity › Forums › Maxon Cinema 4D › Randomise the same texture across several different objects
  • Randomise the same texture across several different objects
    Posted by Xavier Bonet on May 21, 2018 at 4:21 pm
    I’ve several objects in my scene that are supposed to be hanging moss, and for that purpose I’ve created a texture that includes a displacement made of noise. Now, I’m wondering how to get the texture on each individual object to randomise that displacement (i.e. randomise the noise that makes the displacement), so that all of my objects don’t seem like clones of the same object, which is what they seem to be now.
    I know I can individually manipulate the texture on each object but I’m wondering if there’s a more time-saving way of going about doing this, which surely would be an asset to my workflow in the future.
    As this is an animation, I can’t use the “world” space option for the noise, as it would slip as the the moss objects dangle and play around with dynamics. So I tried all other options and I either get the texture to stick but it’s the same in all objects, or the texture varies and it slips. The last I tried was the “raster” option, which gives me the very best displacement for my purpose but, again, it slips as the object moves. This last I’m not sure why, because the textures are set to UVW Mapping; I understand why “world”, “camera”, etc., would slip… but I can’t find info on what “raster” does, so it’s still a mystery.
    If there’s a way of using “raster” and keeping it from slipping, that would be great
    Thanks in advance for your input!
    Steve Bentley replied 8 years, 4 months ago 3 Members · 4 Replies
  • Brian Jones
    May 22, 2018 at 12:28 am
    I can’t test right now but I would be trying to randomize the seed of the noise, if I understand correctly.
  • Steve Bentley
    May 23, 2018 at 8:25 am
    I’m not sure changing the seed will work because its still one texture over many objects. So the noise will change but it will change on all objects linked to that one texture. (more on this kernel of an idea in a sec)
    Good try with the world space, thats usually the first best solution but you are right with it waving around the moss is literal traveling through the 3D noise field.
    I wonder if you made a link list of the moss objects in Expresso and then linked a single texture to them all but one where you fed in a noise to that texture, and into that noise feed a seed number, where the seed that is fed in is the iteration number of the moss object in the link list. That way you get a different noise for each object and that seed number is individually consistent for each object.
  • Xavier Bonet
    May 23, 2018 at 11:08 am
    Hi, Brian and Steve!
    Both your suggestions sound great! I haven’t yet played around much in depth with XPresso, so I’m not sure I would know where to start with either randomising the seed specific to one shader (which I’m assuming can only be done through XPresso) or making the list of objects all with one texture and then feeding in the a random noise (though this one seems like I could find out on my own through trial and error, but still the how to feed a number into a specific shader I don’t know). If you guys could recommend a resource I could read or a tutorial I could watch that would guide me better toward something like this, I would really appreciate it!
    In the meantime, I have a sort-of-solution, as I continued researching into solving this issue. I found this tutorial: https://vimeo.com/51232088. Basically, the solution offered there was similar to the only solution I could think of in the beginning (that of manually changing the U and V offsets of each texture in each individual object) but to do it mechanically, through XPresso, and therefore have it be painless! Basically it’s similar to your ideas, but the random number being created is used to change the U and V offset values. Which is why it’s a sort-of-solution, because the texture is the same, it’s only offset. So in certain cases it’ll work as “different textures”, and the objects won’t look like clones; but in more detailed cases, one will see that there’s an offset rather than the true random generation that occurs in natural objects. It works for me in this particular case, however. Still, I’d like to learn other ways of solving this for the future.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Steve Bentley
    May 23, 2018 at 4:10 pm
    Actually if that works that’s brilliant. I hadn’t thought of shifting the UV’s. It would be the same process as the seed change in Expresso. (i’ll give this a whirl later and upload a sample if it works)
    But (and I’ll have to keep looking for examples we’ve done) we’ve tried a number of times to have different iterations of the same texture on different objects (the Mograph shader can work sometimes – even on non cloner objects), but we’ve rarely been able to get there. I think it has to do with C4d (and expresso) populating and calculating geometry every frame, while the textures sort of live forever and are global. While you can pull textures into expresso they don’t have the same flexibility or iterational (irritational perhaps) ability.
