Activity › Forums › Adobe After Effects › random wiggle, toggle hold
  • random wiggle, toggle hold
    Posted by Accountclosedduetonorealnameused on September 29, 2007 at 5:46 pm
    I am trying to create an expression for position, a random wiggle, but with toggle hold.
    So the layer jumps from one spot to the next, not traveling from one spot to the next. With some sort of control on distance moved and frequency.
    I can get the wiggle, just not the toggle hold part of it.
    any ideas?
    Dan Ebberts replied 19 years ago 3 Members · 2 Replies
  • Mike Clasby
    September 29, 2007 at 6:20 pm
    Ok, a real expression guy should be able to do this, not me, but here’s an easy solution. Put this expression on a New Null layer’s Position:
    holdTime = 1.0; //time to hold each position (seconds)
    minVal = [0.1*thisComp.width, 0.1*thisComp.height];
    maxVal = [0.9*thisComp.width, 0.9*thisComp.height];
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    random(minVal,maxVal)
    That will make the Null randomly assume a position within the screen, holding for 1 sec. Change holdTime, minVal, maxVal as needed.
    Now add your real layer, and parent it to the Null (Null is Parent). Add your wiggle expression to the real layer.
    The Random Hold part is from Dan, here:
    https://www.motionscript.com/mastering-expressions/random-1.html
    When I tried to add wiggle into Dan’s expression, it jumped down and right, offscreen, so the Null was the solution for me.
  • Dan Ebberts
    September 30, 2007 at 3:07 am
    Depending on what you’re after, it might be as simple as something like this:
    posterizeTime(3);
    wiggle(5,200)
    Dan
