Activity › Forums › Adobe After Effects Expressions › Random value every X frames offset?
  • Random value every X frames offset?
    Posted by Daniel Rivas on August 26, 2020 at 3:58 pm
    Hello, I’m using a simple random expression every 13.7 frames (every beat of a song) but the expression begins 5 frames into the clip (instead of 13.7 frame, a beat), so the effect changes every half beat, I need it to change every beat. I’m pretty new to expressions and I’m wondering if there’s a way to offset the beginning of an expression if i’m not missing something. Thanks.
    Composition fps = 23.976
    Song bpm = 105
    period = 13.7; // frames
    posterizeTime(1/(period*thisComp.frameDuration));
    random(-50,50);
    Daniel Rivas replied 6 years, 1 month ago 2 Members · 6 Replies
  • Dan Ebberts
    August 26, 2020 at 4:27 pm
    Try it this way:
    seed = Math.floor(time/(period*thisComp.frameDuration));
    seedRandom(seed,true);
    random(-50,50);
    Dan
  • Daniel Rivas
    August 26, 2020 at 4:51 pm
    Hey, thanks for the quick response. The expression still applies every half beat but I thought I’d add that i’m using this expression on a trimmed adjustment layer that lasts 109 frames. I apologize in advance if the problem has been something obvious I haven’t noticed.
  • Dan Ebberts
    August 26, 2020 at 4:53 pm
    Where does the first beat occur relative to the layer’s in point?
    Dan
  • Dan Ebberts
    August 26, 2020 at 5:06 pm
    This might work better:
    offset = 5; // first beat relative to in point
    seed = Math.floor((timeToFrames(time-inPoint) – offset)/period);
    random(-50,50);
    Dan
  • Daniel Rivas
    August 26, 2020 at 5:09 pm
    The first beat lands on the layer’s in point so I think ideally the expression should wait for the first 13 frames and then apply the random.
  • Daniel Rivas
    August 26, 2020 at 5:13 pm
    Hey, that worked. Just changed the offset to 13.7 and the effects are now vibing with the beat.
    Thanks a lot Dan.
    offset = 13.7; // first beat relative to in point
    seed = Math.floor((timeToFrames(time-inPoint) - offset)/period);
    random(-50,50);
