Activity › Forums › Adobe After Effects Expressions › Random positions
  • Posted by Jorge Lavín on September 21, 2011 at 4:20 pm
    Hey everyone.
    This is my firts question as I am new to After effects and found this forum.
    Well, I have a composition with many layers (more than 200 pics) I needed to spread them appart so I used this expression in each one:
    range = 10000;
    x = random(-range,range);
    y = random(-range,range);
    z = random(-range/2,range/2);
    [x,y,z];
    The thing is I want them to stay in that position, but I found that they change every frame. How can I resolve this?
    Thank you.
    range = 10000;
    [x,y,z];
    Amy Young replied 9 years, 5 months ago 3 Members · 5 Replies
  • Dan Ebberts
    September 21, 2011 at 5:10 pm
    Just add this as the first line of the expression:
    seedRandom(index,true);
    Dan
  • Jorge Lavín
    September 21, 2011 at 10:01 pm
    Thanx Dan, it worked!
    Now I have another problem 😛
    hope someone can help me, what I want to do now is to convert the random values generated with constant numbers since I made some camera moves over the spreaded pics, saved the proyect and (I really dont remember if I closed it and opened it again) the values changed, I mean the pics are now on different locations.
    Thank you again
  • Dan Ebberts
    September 21, 2011 at 11:02 pm
    That will happen if you add new layers above the ones with the expression.
    You can always select the position property, and then Animation > Keyframe Assistant > Convert Expression to Keyframes. You can then delete the keyframes if you want.
    Dan
  • Jorge Lavín
    September 21, 2011 at 11:16 pm
    Thank u again Dan!
  • Amy Young
    April 15, 2017 at 9:40 pm
    Thanks Dan! Neato!
