Activity › Forums › Adobe After Effects › Random Opacity Characters After Effects CS6
  • Random Opacity Characters After Effects CS6
    Posted by Joao Laureano on January 9, 2014 at 1:44 pm
    Hello all,
    I’m trying to recreate this motion on some text – where the characters would appear and form words in a random way to then again disappear in the same fashion.
    The example is in this link at https://vimeo.com/channels/nicetype/6753187
    Would you have any thoughts on how to achieve it? Most expressions I have found weren’t really able to deliver the effect as in the example here, so I was thinking maybe there is an easier way to recreate that.
    Any advise is highly appreciated,
    Joao
    John Cuevas replied 12 years, 8 months ago 2 Members · 3 Replies
  • John Cuevas
    January 9, 2014 at 2:20 pm
    You need to add an opacity text animator to to your text. Create your text, and twirl open the properties, click the “animate” pulldown and choose opacity. Change the opacity to 0. Twirl open the advanced properties, and change the mode to “Subtract” and randomize order to “On” Twirl open the Range Selector. Animate the “End” selector from 0 to 100%.
    You can find a ton of great info on Text Animators in After Effects basics tutorials by Andrew Devis
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Joao Laureano
    January 9, 2014 at 3:33 pm
    Thanks for your prompt feedback John, that did the trick! Will definitely look into Andrew’s tutorials as well,
    Cheers
    Joao
  • John Cuevas
    January 9, 2014 at 4:51 pm
    Glad I could help. Definitely, check out the stuff on text animators, they are really powerful and you can create some awesome animations with them. Also, if you check look on the Menu Bar > Animation > Browse Presets and click the Text folder, you can browse through the presets that Adobe ships with AE.
    Thinkck.com
