Activity Forums Adobe After Effects Expressions Random number from array to target layer
  • Random number from array to target layer
    Posted by David Wiffen on November 22, 2010 at 4:18 pm
    Hi Everyone,
    Ok hopefully this is simple enough. Here’s my expression…
    posx = thisComp.layer(“Emitter.2”).transform.position[0];
    posy = thisComp.layer(“Emitter.2”).transform.position.wiggle(thisComp.layer(“WiggleEmitter”).effect(“Freq”)(“Slider”),thisComp.layer(“WiggleEmitter”).effect(“Amp”)(“Slider”))[1];
    [posx,posy];
    All I want to do is where it references “Emitter.2” I want to have an expression that says randomly select an number from an array of x amount and apply to this reference. So when I duplicate the layer up it will pick a different number each time.
    Eg. Emitter.1 / Emitter.2 / Emitter.3 / Emitter.2/ Emitter.1 / Emitter.3 and so on…
    Hope that makes sense!
    David Wiffen replied 15 years, 10 months ago 3 Members · 5 Replies
  • Dan Ebberts
    November 22, 2010 at 4:59 pm
    This would be one way to randomize references to the 3 layers:
    seedRandom(index,true);
    n = Math.floor(random(3)) + 1;
    emitterName = “Emitter.” + n;
    posx = thisComp.layer(emitterName).transform.position[0];
    Dan
  • David Wiffen
    November 22, 2010 at 5:15 pm
    Very impressive – Thanks Dan!
    One more question…If I have other expressions on the same layer that I want to have the same value as what the random expression chooses…how would I do that?
    eg.
    This is on position x and y and works great:
    emitterName = “Emitter0” + n;
    posy = thisComp.layer(emitterName).transform.position.wiggle(thisComp.layer(“WiggleEmitter”).effect(“Freq”)(“Slider”),thisComp.layer(“WiggleEmitter”).effect(“Amp”)(“Slider”))[1];
    [posx, posy] – value + wiggle(thisComp.layer(“WiggleEmitter”).effect(“Freq”)(“Slider”),thisComp.layer(“WiggleEmitter”).effect(“Amp”)(“Slider”));
    This is on the z and needs to have the same random value as the x and y have for the emitter number:
    thisComp.layer(emitterName).transform.position[2];
    thanks again Dan – you’re talented guy!
  • Dan Ebberts
    November 22, 2010 at 8:07 pm
    You’d have to put the random calculation on a slider control and have both expressions pick it up from there. The expression on the slider would just be:
    Dan
  • Lloyd Alvarez
    November 22, 2010 at 9:28 pm
    You could add a slider control and generate the random number there then have X and Z get the number from there.
    This is the code you should put on the slider control:
    And this would be the updated code for Z:
    n=effect("Slider Control")("Slider").value;
    emitterName = "Emitter0" + n;
    -Lloyd
    https://aescripts.com
  • David Wiffen
    November 23, 2010 at 9:20 am
    Brilliant – thanks Both!
    Really really appreciate it!
