Activity Forums Adobe After Effects Random jump in video levels upon rendering comp
  • Random jump in video levels upon rendering comp
    Posted by Adam Taylor on April 30, 2008 at 12:26 pm
    I’m having a really odd problem with my current project.
    I am doing a simple rotoscoped wipe using an animated mask to reveal a change of clothes for a character. There are two shots that make up the second clothes set and so i have precomped these.
    I’m working with pal widescreen 10bit uncompressed footage, and rendering back out to the same format.
    When i play back directly on the timeline the effect works perfectly. As soon as i render it (or do a Ram preview) i get several frames into the clip and the video levels leap by 5-10% (according to my scope). I have rendered this almost a dozen times now, and the frame when the leap occurs appears to be random.
    I have checked every clip and they all seem normal. I have no filters or keyframes or anything i can think of that could cause such a leap. In fact, all i have are the pre-comp and one other video track with a single feathered mask to do the wipe with.
    Any suggestions of things to try? I have already rebooted the mac, and used macjanitor to clean out its cache etc.
    thanks
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    Adam Taylor replied 18 years, 4 months ago 2 Members · 2 Replies
  • Joey Foreman
    April 30, 2008 at 1:43 pm
    I’ve seen something like this before. I recommend making a new project and importing your project as a file. Open your comp again and see if the problem persists. Also turn off Open GL if it’s on – although I don’t think Open GL is involved in rendering.
  • Adam Taylor
    May 2, 2008 at 12:37 pm
    hi joey,
    tried all those things and no luck. I even tried starting a new project from scratch but it still did it.
    In the end i got round it by making the run up to the bit i needed longer, so i could edit the jump later, and also re-correct the levels in color grading app later.
    Its quite worrying because i think i just saw it happen on a completely different project…but i could have just blinked whilst watching the render!!
    adam
    Adam Taylor
    Oldham, UK
