Activity Forums Adobe After Effects Expressions Random Hexadecimal digits
  • Random Hexadecimal digits
    Posted by Navarro Parker on November 28, 2012 at 10:52 pm
    I have this expression that will display random hex letters if put into a text layer’s Source Text parameter:
    rate = 5;
    seed = Math.floor(time*rate);
    seedRandom(seed,true);
    String.fromCharCode(65 + Math.floor(random(6)));
    If I lower the starting CharCode from 65 to 48 to include numbers, I get unwanted punctuation symbols from 58~64.
    How can I generate purely hex digits?
    Dan Ebberts replied 13 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    November 29, 2012 at 12:09 am
    Try changing the last line to this:
    Math.floor(random(16)).toString(16).toUpperCase();
    Dan
  • Navarro Parker
    November 29, 2012 at 2:00 am
    Brilliant as always!
    Can you explain a little bit how that works? Are the symbols being ignored because of the .toUpperCase command? The (16) doesn’t seem to correspond to where the letters are in ASCII table.
  • Dan Ebberts
    November 29, 2012 at 2:13 am
    Using 16 as an argument for toString() causes the random integer (0 to 15) to be converted to a hexidecimal (base 16) representation of the number. If you leave off the toUpperCase(), “A” thru “F” will be “a” thru “f”. The ASCII table doesn’t really enter into it.
    Dan
