Activity Forums Maxon Cinema 4D Random Effector Not Affected By Change In Project Fps
  • Random Effector Not Affected By Change In Project Fps
    Posted by Steve Layton on October 24, 2013 at 1:57 am
    I am trying to create a sequence in mograph where there is a sudden slow down in time in a scene with a bunch of cloned objects that have the random effector applied. In this slow motion sequence I am using a frame rate of 300 as oppose to 30, however, I cannot get the random effector’s speed to respond to a change in the project fps. The random effector maintains its speed even though everything else in the scene has changed its speed (relative to the playback framerate). I have tried mograph cache tags on the cloner object it is affecting with no luck. What do I do? I can’t find any help on this…
    Steve Layton replied 12 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 24, 2013 at 5:32 pm
    You can change, or animate, the random effector’s speed in the Effector tab. Another option would be to apply a Delay Effector with a high strength setting.
  • Steve Layton
    October 24, 2013 at 6:47 pm
    The animation speed technique won’t work. (a sudden change in animation speed won’t let it pause without “bump”). The delay effector is something that I can work with though. Thank you for this suggestion, it saves me a big hassle. Take Care!
