Activity Forums Adobe After Effects Random Color with Parameters
  • Random Color with Parameters
    Posted by Nick Adcock on October 25, 2010 at 8:01 pm
    Perhaps someone…cough…Dan Ebberts….has posted or has already created an expression for this. I have 8 colors I would like to cycle through randomly for say 5 frames at a time and hold on that color not blend between them. I’ve seen quite a few random color posts but none with these parameters.
    Thank you Thank you
    Nick Adcock replied 15 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 25, 2010 at 10:05 pm
    you could add the fill effect to the layer, add 8 keyframes to the color property, setting a unique color for each keyframe.
    then use an expression like this for the color property:
    posterizeTime(6); // value is in fps
    r = Math.ceil(random(0,numKeys));
    valueAtTime(key(r).time)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Nick Adcock
    October 26, 2010 at 7:54 pm
    Kevin,
    Thanks very much. That worked well.
