Activity Forums Apple Final Cut Pro Legacy RAM Question for FCP 5
  • RAM Question for FCP 5
    Posted by Hopperhd on December 29, 2005 at 10:12 pm
    I’m looking at purchasing a New – Dual 2.3GHz G5 2GB of RAM FCP 5.
    Question:
    What is the difference between the different types of RAM?
    2G 533 DDR2 Non ECC SDRAM –
    4×512
    2x1GB
    2G 533 DDR2 ECC SDRAM –
    4×512
    2x1GB
    What is the difference between Non ECC and ECC? And out of the combinations listed, what is the best se-up for FCP 5 and what is the best RAM size distribution?
    Jason
    Francois Stark replied 20 years, 9 months ago 4 Members · 5 Replies
  • David Bogie
    December 29, 2005 at 11:18 pm
    EEC RAM is slightly sower. You don’t need it for video.
    For a thorough explanation, just google the RAM numbers. The descriptions are ever so boring.
    bogiesan
  • Hopperhd
    December 30, 2005 at 12:21 am
    I still need the most ideal configuration for FCP 5, based on the available choices:
    G5 RAM Question:
    4×512
    2x1GB
    4×512
    2x1GB
    Thanks again,
    Jason
  • Gunleik Groven
    December 30, 2005 at 7:12 am
    Go with the 1 Gb sticks. It gives much more room when you eventually want to fill the rest of the slots. (And one day you will, I promise!).
    Go non ECC. Wether one is faster than the other is (acording to BareFeats.com) a latency issue. You can have faster and slover versions of both. But for non critical apps (which FCP is considered to be in comparison with a nuclear research app)non ECC is the way to go.
    Gunleik
  • Hopperhd
    December 30, 2005 at 7:39 am
    Thank you sir! This site rocks!
  • Francois Stark
    December 30, 2005 at 8:13 am
    ECC ram will not run in a G5 tower. It is meant for servers and will run in the G5XServe.
