Activity Forums Adobe After Effects Ram Previews getting shorter..
  • Ram Previews getting shorter..
    Posted by James Zwadlo on June 14, 2007 at 3:13 pm
    Hello all 🙂
    Since yesterday ive been having a problem in that my ram previews have been getting shorter and shorter and now im only able to render 2-3 seconds at a time which is infuriating, I have 2 gig of memory so I can usually get about 15 seconds in my ram previews.
    The area im previewing isnt particularly intensive, and i cant figure out why this is happening. If anyone can shed some light I will be very gratefull. Lowering the resolution is only adding a second to the preview time
    thanks in advance
    Steve Roberts replied 19 years, 2 months ago 3 Members · 2 Replies
  • Kevin Camp
    June 14, 2007 at 3:54 pm
    try choosing edit>purge>all… sometimes ae just seems to get bogged down after a while, and manually purging the ram can do the trick.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    June 14, 2007 at 3:56 pm
    Open whatever your OS uses to check RAM usage. See if it is growing a lot while AE isn’t open. Maybe something else is stealing RAM.
    Don’t forget edit>purge.
