Activity Forums Adobe After Effects Ram preview problem!
  • Ram preview problem!
    Posted by Javier Lopez on May 4, 2007 at 11:57 pm
    Hello people,
    I have a problem with ram preview in After Effects, I get this error message: “After Effets error: Ram review needs 2 or more frame to playback”.
    Everything is Ok on my timeline and I can playback my video with no problem, I get the error message when I try Ram Preview or Render.
    Any solution?
    Thanks.
    Steve Roberts replied 19 years, 4 months ago 3 Members · 2 Replies
  • Darby Edelen
    May 5, 2007 at 2:14 am
    This message is usally a result of not having enough frames for a preview, if your playhead is at the end of the comp and you have it set to render from the playhead for example, or if your comp is less than 2 frames long (for some reason). However, I have also gotten this error somewhat randomly. Usually rebooting After Effects will fix this if Edit>Purge>All doesn’t.
  • Steve Roberts
    May 5, 2007 at 6:27 am
    In my experience, it’s a goofy error that can be cleared by restarting AE. It makes no sense, but there you go.
