Activity › Forums › Adobe After Effects › Ram Preview not realtime
Posted by Legend on July 1, 2006 at 6:30 pmI have a comp it is NTSC D! it consist of only PSD files when I ram preview my animation I get a red reading in the info stating not realtime and the frame rates are not paling back at 29.97, An idea what’s wrong.
Majorasshole replied 20 years, 2 months ago 5 Members · 6 Replies -
Vince Becquiot
July 2, 2006 at 5:43 amThat’s common issue if you are limited in ram speed and CPU power.
The workaround, other than a computer upgrade, is a preview monitor.
Vince
Serge Hamad
July 2, 2006 at 3:46 pmAlso check in your Ram Preview Options that the skip option is set to (0).
Salut.
Serge“InvigoMany” Available here:
https://www.nyc-visual.com -
Legend
July 2, 2006 at 7:48 pmI have a quad g5 with 4 gigs of ram and a nvidia 4500 graphics card with 4.0 terabytes of storage on an xraid out put to a 42″ HD Plasma preview monitor. The skip is set to 0 and I still have the same problem.
Legend
July 2, 2006 at 9:23 pm720×480.. I am use to the ram preview continuing to loop until the space bar is pressed. When I hit the ram preview it goes through the first run then stops its not calculating frames then previewing the comp. when I hit the tab it goes straight thru.
Majorasshole
July 4, 2006 at 5:24 ami had framerate issues just hitting the space bar, but if i clicked the ram preview button and let it make all the frames then it will play back real time once it is done.
