Activity Forums Adobe After Effects Ram preview needs at least two fm’s
  • Ram preview needs at least two fm’s
    Posted by Peter on June 27, 2005 at 6:52 am
    I just installed a try out version of AE from the Adobe site.
    I get an error msg on Ram preview as stated in the subject of this
    post.
    I have used AE on that comp before with no problems.
    Anyone know what may be causing this. The timeline does contain fm’s
    and keyframes et.. btw
    Cheers
    Trug
    Peter replied 21 years, 3 months ago 4 Members · 4 Replies
  • John Dickinson
    June 27, 2005 at 7:18 am
    Check your work area. You’ll get this error message when your work area is set to 1 frame.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Michael Duff
    June 27, 2005 at 7:24 am
    hit “B” to start work area, then “N” where you want the preview to end
  • Aharon Rabinowitz
    June 27, 2005 at 1:26 pm
    I get this problem a lot when there is a memory leak. If you have not already done so, shut down and restart the computer.
    That usually clears it up.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Peter
    June 28, 2005 at 1:13 pm
    Thanks for the above.
    Still have the same problem. It is an old comp so not to worried about it.
    Just curious is all. I will reinstall the software and see what happens
    Trug
