Activity Forums Adobe After Effects Ram Preview in After Effects CS4
  • Ram Preview in After Effects CS4
    Posted by Patrik Gyllström on February 11, 2010 at 9:51 am
    Hi
    I have a 30 sec comp in 1920×1080 that is basiclly a DXP sequence with tre text layers. I am in despreat need to do a full ram preview. But I can only do 15 sec.
    Any sugesstions that can help me.
    Mac Pro 2×3 GHz Quad Core, 9 Gig Ram, OS x 10.5.6
    Todd Kopriva replied 16 years, 7 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 11, 2010 at 4:13 pm
    First, why don’t you just render and export the full 30 seconds and view the movie?
    But, if you absolutely must have a 30-second RAM preview, then you’ll need to do something to decrease the RAM required per unit time. You can decrease the resolution, you can set RAM preview to skip every other frame, you can decrease the color bit depth… That’s why there are these options at the bottom of the Preview panel.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Todd Kopriva
    February 11, 2010 at 5:43 pm
    The RAM preview frames are all held in the memory space of one process (called the foreground process). Because After Effects is a 32-bit application, the theoretical limit for the amount of RAM that that process can use is 4GB. There are other things eating that RAM, too. See the comment at the bottom of this page for the nitty-gritty details.
    So, your 9GB is useful for rendering multiple frames at once and for giving your operating system and other applications plenty of RAM while you work with After Effects. But only 4GB is used by the process that stores RAM previews.
    As Dave says, the next major version of After Effects will be a 64-bit application. That means that the theoretical limit for the amount of RAM that one application process can use is absolutely huge—way beyond what you can fit in a computer. But operating systems do impose some limits of their own. I can’t give details now, but I will go right up to the line of what I can disclose and say that I’ve seen some very impressive RAM preview durations with the software currently in development.
