Activity › Forums › Adobe After Effects › Ram Preview Delay after upgrade
Posted by Michael Heid on July 15, 2015 at 11:40 amI hope there’s a simple solution to this, but since upgrading to Yosemite 10.10.4, there is now a 1sec delay on starting the ram preview. This happens on both CC 2014 and CC 2015.
To elaborate, when I hit the 0 on the number pad, it ram cashes, and then on preview, it doesn’t start audio and video until a full second after the point where I initiated it on the timeline. I have to loop it to see the full preview.
Any ideas?
MichaelMichael Heid replied 11 years, 1 month ago 3 Members · 7 Replies -
Todd Kopriva
July 15, 2015 at 3:08 pmI am very surprised to see you say that this occurs on After Effects CC 2015 (13.5), too.
The problem was because of a bug in Mac OS that we worked around in the latest update to After Effects.
After Effects product manager and curmudgeon
After Effects team blog
Michael Heid
July 15, 2015 at 3:17 pmI should revise that. In 2015 the Video does start properly, but the audio still has the delay. Also, just doing the period button creates a delay. I was able to solve that problem by deselecting “Mute Audio When Preview is Not real-time” in the Previews Preferences and also changing “preview favors” to length.
Todd Kopriva
July 15, 2015 at 5:22 pmOK. That fits what I expected.
We’re fixing the audio delay in an update due out in two weeks.
Steven J casey
July 21, 2015 at 3:34 pmIs this fix also for Windows machines? I came to the forum to look for this issue and see this reference to Mac, assume you know it happens 100% of the time on Windows as well. It’s not a consistent delay, sometimes one second and sometimes several.
Todd Kopriva
July 21, 2015 at 3:41 pmThe audio delay and its fix are not specific to any OS.
Todd Kopriva
July 28, 2015 at 6:44 amThe After Effects CC 2015 (13.5.1) bug-fix update is available: https://adobe.ly/1Il5JYe
Michael Heid
July 28, 2015 at 8:13 pmThanks Todd,
After day 1 working in the new AE,
the period button does work, but it no longer will advance the time marker if there is no audio. Sometimes it’s helpful to hit period to advance your timeline in realtime so you can time things out without audio.And while we’re at it:
Guide layers don’t work if an adjustment layer containing Posterize Time effect is above it.
There’s some bug that happens when you hit space bar to manipulate a mask point position. (upon releasing the space bar/hand tool, it gets stuck)
Keyframes still “stick” to your mouse when you try to move them in the timeline.
Still no icon render bar.I’ll put in bug reports later this evening, but thought they were worth mentioning.
Thanks again,
Michael
