Activity › Forums › VEGAS Pro › RAM Preview crashes Vegas Pro 9c
  • RAM Preview crashes Vegas Pro 9c
    Posted by Paul James chatman on March 18, 2010 at 3:44 am
    Hmmm? I can’t seem to figure out how this happened. But for last few months Vegas has been crashing after i do a RAM preview. It will let me view it the first time. But then if I preview it again, it will play, but as soon as it stops – the PLAYHEAD gets stuck in PLAYMODE, and the application freezes. Other times , this occurs, after the first preview.
    I thought it was the RAM cache was to to high so i set it for the defaulkt of 384mb. Still crashes.
    I did have both 8c and 9c on the system, but un-installed 8c after getting settled with 9c. This can’t be be related, can it? That’s silly.
    Yeah, I could preview to player, but the RAM preview is convenient and right there. Any ideas?
    PaulJC
    hello
    John Rofrano replied 16 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    March 18, 2010 at 10:04 am
    You might hope that it’s not, but Vegas shares a lot of components and uninstall one version has the potential to affect the others. I would hope it’s not related but if it’s the only thing that you changed about your system from when it worked and when it didn’t, then it could be related. 🙁 (I doubt it though because it does play the first time)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Paul James chatman
    March 19, 2010 at 8:29 am
    I used the Pre-rendered option, and it doesn’t crash after a viewing. But is it normal to cut the previews into little bits? I selected a 29 second clip and it pre-rendered it into 4 separate clips. Is that normal?
    hello
  • John Rofrano
    March 19, 2010 at 5:33 pm
    That might depend on your media type and what can be smart rendered and what needs to be re-rendered.
    ~jr
