Activity › Forums › Adobe After Effects › ram player
  • ram player
    Posted by Simon Brewster on March 11, 2007 at 5:46 am
    hi, new to after effects usually use discreet stuff…i am having problems getting full speed ram playback ….as soon as i add a adjustment layer or precompose i do not get real time playback.. ?
    simple pal project ,3 gigs of ram, hp workstation, blackmagic video to sony monitor, ae7pro
    thanks
    s
    Kevin Camp replied 19 years, 6 months ago 3 Members · 3 Replies
  • Michael Duff
    March 11, 2007 at 6:50 am
    so you are actually doing a RAM preview (hitting 0 on the keypad) rather than just hitting space bar? you need to hit 0 on the keypad, wait for it to render into RAM, you’ll see the green bar building, when it has done as much as it can it will play back… sometimes you need to let it play through a couple times before it plays in real time.
    does this help?
  • Simon Brewster
    March 11, 2007 at 8:59 am
    hi thanks for your reply
    well space bar is managing 14.6 fps and 0 is managing realtime mostly maybe dropping back to 24.7 …i shall read some more! but what is the difference between spacebar and 0… i know i should not do this but combustion just plays it back… : )
    i have to say its nice working on ae7 though
    s
  • Kevin Camp
    March 12, 2007 at 3:53 pm
    ‘spacebar’ will render to disk and play from disk.
    ‘zero’ from the #s pad will render to ram and playback from ram.
    since ram is access is faster than disk access you have a much better chance of realtime playback by hitting the zero on the #s pad.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
