Activity Forums Adobe After Effects RAM getting unusually overloaded
  • RAM getting unusually overloaded
    Posted by Stuart Samuels on June 17, 2014 at 9:39 am
    Hi.
    I have a MacBook Pro with 8gb RAM.
    Recently while working within AE the RAM has been getting overloaded VERY quickly. I have tried creating some extremely simple compositions and the problem persists. I’ve worked on much more complex jobs in the past without the problem, I have plenty of space on my hard drive, cleared the cache, closed all other programs, ran a memory clean program but it makes no difference.
    Does anyone have any ideas why this might be happening all of a sudden and any suggestions on how to fix it?
    Stuart
    Stuart Samuels replied 12 years, 2 months ago 3 Members · 6 Replies
  • Walter Soyka
    June 17, 2014 at 2:24 pm
    What do you mean by overloaded?
    Are you seeing any slowdowns or errors, or just high RAM usage?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Stuart Samuels
    June 17, 2014 at 2:46 pm
    Hi Walter.
    I’m getting a lot of slowdown and very high RAM usage (up to 95%).
  • Walter Soyka
    June 17, 2014 at 2:52 pm
    Have you changed anything on the system recently? Updated software or third-party effects?
    Have you upgraded to Mavericks? Do you have App Nap turned off for Ae? What’s the Activity Monitor memory pressure graph look like during a render?
    Walter Soyka
  • Stuart Samuels
    June 17, 2014 at 3:40 pm
    Yes I have upgraded to Maveriks
    App nap is off for AE
    The graph stays pretty reasonable but the Memory Used reaches 7.99gb of the 8 available.
    The machine then grinds to a halt and doesn’t recover until I run a memory cleaning app.
  • Todd Kopriva
    June 17, 2014 at 3:49 pm
    Try enabling the Reduce Cache Size When System Is Low On Memory preference:
    https://blogs.adobe.com/aftereffects/2012/10/after-effects-cs6-11-0-2-update-bug-fixes-and-added-gpus-for-ray-traced-3d-renderer.html
    After Effects team blog
  • Stuart Samuels
    June 18, 2014 at 9:12 am
    Thanks. I’ll give this a try and keep my fingers crossed.
    Stuart
