Activity › Forums › Apple Final Cut Pro › Raising audio level with mouse moves clip
Posted by John Davidson on June 21, 2012 at 1:03 amWhen I want to raise the audio level on a clip, I put my mouse over it, see the little audio level indicator signifying that I’m over the audio VU level – click to raise it and OOPS, I moved my clip instead. This happens about half the time, resulting in repeated keystrokes, undoing, etc.
Is there a science to changing the volume level with a mouse that I’m missing?
James Ewart replied 14 years, 1 month ago 6 Members · 10 Replies -
Tom Wolsky
June 21, 2012 at 1:36 amMake sure you’re not using the position tool.
All the best,
Tom
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
“Complete Training for FCPX” from Class on Demand
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy” -
John Davidson
June 21, 2012 at 1:59 amI rarely use the P tool. It’s a pretty strange little quirk. Before I click to raise the clip everything looks right and ready to raise, then I click and sometimes it raises it, and other times it moves the clip. Mostly I use cntl+ or -, but for larger volume increases the clip itself is theoretically faster – when it stays put.
John Davidson | President / Creative Director | Magic Feather Inc.
David Eaks
June 21, 2012 at 6:54 amThe exact same thing has been happening to me recently, pretty annoying. I’m on 10.0.4.
Loren Risker
June 21, 2012 at 10:49 pmSame here on 10.0.5
It drives me crazy. I just adjust the clip height and find its easier to grab.
OutOfFocus.TV – Music videos, docs, entertainment. -
Tom Wolsky
June 21, 2012 at 11:36 pmIs the connected audio on a layer above the primary storyline or below it?
All the best,
Tom
Dave Gage
June 21, 2012 at 11:51 pm[Loren Risker] “It drives me crazy. I just adjust the clip height and find its easier to grab.”
Me too with the clip height. I’ve ultimately found it easier though to select the clip, go to the Inspector/Audio tab, and then type in the number there or use the UP/DOWN arrows.
Dave
John Davidson
June 22, 2012 at 1:47 amGlad to know I’m not alone. This doesn’t matter on mine whether I’m above or below the primary, it happens A LOT.
Maybe it was changed in .05 as a reaction to accidentally adjusting volume when you are moving the clip. This is a byproduct of having so many clickable elements within a clip in a project. How many times do you guys accidentally click the top left of a clip and open up that pop up when all you wanted to do was drag a clip around a bit? I love all the stuff we can adjust mouse-only, but sometimes it gets in the way of actual editing.
You know – perhaps in 10.05 the higher resolution of the project timeline creates a situation where this specific issue doesn’t occur, but at lower resolutions it does.
Tom Wolsky
June 22, 2012 at 1:58 amNot seeing this.
All the best,
Tom
John Davidson
June 22, 2012 at 2:09 amOn a 2009 mac pro with external monitor on it seems a little easier to recreate. On a current iMac it still happens, but far less often.
James Ewart
August 22, 2012 at 4:10 pmDon’t know if you got a solution to this but for me the keyboard shortcuts for raising and lowering volume do not work
