Activity › Forums › Storage & Archiving › RAID5 possible with SONNET FUSION D500P?
Thomas Miller replied 14 years, 4 months ago 4 Members · 12 Replies
Luis Rodriguez
April 25, 2012 at 6:08 pmThe 2314 is not a true “hardware” RAID controller and will use your system resources. The card will see the various drives as a disk pool and allow you to manually group the drives into user defined RAID sets or individual volumes.
Luis Rodriguez
Proavio
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X109
Fax: 562-777-3499
Email: luis@proavio.com -
Thomas Miller
April 25, 2012 at 9:16 pm[Luis Rodriguez] “Bob is right on the money in regard to Highpoint’s support department. It just doesn’t exist. On the other hand, if you absolutely need RAID 5 and are not in a position to ditch your Sonnet array for MiniSAS or Thunderbolt, you will have a hard time finding a reliable and well supported alternative in the market. You can also check with vendors such as Promax to see what they offer in terms of RAID 5 in eSATA. It may be worth your while to purchase the controller from a vendor that will back the product with support.”
Yes, I absolutely agree with that. The other option we might choose, that we just don’t use the Sonnet D500P arrays any more and buy an new enclosure with an integrated RAID5 controller.[Luis Rodriguez] “The 2314 is not a true “hardware” RAID controller and will use your system resources. The card will see the various drives as a disk pool and allow you to manually group the drives into user defined RAID sets or individual volumes.”
Okay, do you know how the card gives the possibility to build a Software RAID5 on a Mac, which can’t to that at it’s own via the included software?
